Still having tach problems.
gunz
Yukon Oklahoma
So I installed a new tach sensor today, Still reading real low. Idle is around 400 adn gettin into it still never goes above 1K. Tach nedel moves steady, just not reading right. Any ideas?
I will try to check the grounds when I get a chance. What are the odds that the gear teh sensor reads of has a broken or missing tooth cuasing the tach to read low.
gunz
Yukon Oklahoma
Alright, i was wondering if one tooth was made a little taller or with different metallurgy to set it apart.
I havent been into this motor yet. so i am guessing. Grounds look good, Shifts have smoothed out, but the tach is still low. .
gunz
Yukon Oklahoma
Yes threads look good. i ran a jumper from the ground to the sensor with no change.
I am searching for a pciture of the IP timing gear for the 7.3 to help me wrap my head around it better.
itsacrazyasian
residentcrazyasian
boca raton, fl
no check your ground at the back of the instrument cluster. i forgot what pin it is but my truck had a bad ground there and it would read very low.
gunz
Yukon Oklahoma
Mine works all the time. lights on or off. Just always really low. I think the ground on the gauge panel makes the most sense. Just have to find out which wire on the plus it is.
flareside_thun
Reviving The General Tao
Tavares, Florida
Usually the wires that go bad on the sensor are right at the sensor itself. The oil leaks through the sensor and out where the wires go into it. I think what Patrick said makes the most sense as well...
Knuckledragger
Payson, AZ
You are thinking too much. The sensor is only a magnet that picks up differences when each gear tooth swings by. The tach operates on the different speed of signals the sensor sends to it.
rhkcommander
Oregon
heres a pic of a tach back:thumbsup:
Bo17
