steering pump kit
Exekiel69
The one on my truck is making noise for a while so I guess is going bad, now I recall someone posted about a rebuild kit for the steering pump so please correct Me if I'm wrong.
Thank you.
Mr_Roboto
Elyria, near Cleveland Ohio
There are rebuild kits for steering boxes, I've never seen one for a power steerign pump. You should be able to get a reman pump pretty cheap at any auto parts store.
typ4
Newberg,OR
Napa has a cast iron style replacement for our ford aluminum pumps, dont know the number offhand but it solves a lot of noise problems on our equipment. There is a big picture of it in thier Power Steering reman book.
sassyrel
iowa
me thinks the cast iron replacement is the old style pump--will maybe bolt right into the bracket--the pulleys will switch--but--the pressure hose has to be changed--the fitting end to the pump is diff--
typ4
Newberg,OR
The one they supply has a fitting to mate up with the ford hose and the shaft is longer for the pulley, there is also a cast adapter bracket on it so it bolts right up.
The part number is napa extra duty pump#20-6244
walk in is 103.00
Exekiel69
walk in is 103.00
;Sweet Man Thank You.
TLBREWER
Windy B Ranch
Moriarty, New Mexico
My original pump finally quit after 230K. Went to Napa and got a new one (don't believe it to be the heavy duty one mentioned, just direct replacement). That one lasted about 3 months til it failed due to internal check valve. Took it back and got it replaced under warranty. That one lasted five weeks. Changing pumps and bleeding steering was getting a little old now. At the advise of a few here, I sprang for a Ford pump and high pressure line (almost $300!). It's been three months and so far so good. Just my .02...I do a lot of business with Napa, but I wouldn't buy another Napa PS pump.
Tom
typ4
Newberg,OR
That is exactly why we went with the heavy duty one the standard replacement doesnt seem to like to be rebuilt. There is just a couple companies that get it right ford and Checker, Shucks, Kragen , have the same pump rebuilder. I think napa goes with the best deal , for them anyway. quality be damned.
