starts and dies!
1dieselman
Page,Az
Yes, if it is sucking air before the lift pump and it gets worse. Maybe you should consider installing a electric fuel pump. Also check the bleed off hose from the filter head down to the injector cap
Exekiel69
If this happen right after You changed the fuel caps and o-rings then You have no sited the caps all the way IN. You can put some grease or Vaseline on the rings and then use a long socket and small hammer to punch them IN just a small firm tap so they sit right.
CDX825
filtration nut
Litchfield,Ohio
It could turn into a bigger leak. I would fix it though because running your engine like that is not good.
IDIcaveman
i like pie
MI
did it before the caps and o-rings. i'm trying to fix it when i can. started with the fuel filter, then caps and o rings. just replaced the hose from feul line to lift pump. it's a work in progress 4 me
IDIcaveman
i like pie
MI
so far restart 1 and 2 after that hose have been good. maybe.... just maybe.
Exekiel69
Ok then You just remove the fuel hoses or inspect them for any cracks then You check the fuel tank selector o-rings and the ones at the fuel tanks if possible (front is easier than rear) that should take care of it.
IDIcaveman
i like pie
MI
ok i'm done for today. thanks for everything and merry christmas
bob123456789
