Starting Troubles!!!!
Camarogenius
Gilmer, TX
:mad: -cuss
So I cleaned up all my battery terminal ends, and in the process found my Starter Solonoid was Cracked, so I replaced the solonoid. now no starty!! :backoff
I get the clicking in the relay on the inner fender behind the Pass. side battery, but no life from the starter. Did I get a bad solonoid, or have I got another problem?
Jump the solenoid with a pair of metal handled pliers, and you'll find out.
Camarogenius
Gilmer, TX
I was going to do that. I'm just not real fond of the Idea of doing that while I'm under the truck.
aaklingler
Winfield, PA
you can also try that on the relay, nuetral, ebrake and front wire on ip pulled. somebody needs to push the clutch pedal down and turn the key get juice to the starter selinoid.
Camarogenius
Gilmer, TX
I Did try it on the relay, and got nothing. The relay would click, but no noise from the starter.
sassyrel
iowa
camaro--those solenoids arent known for being durable--------so-ya might have twisted it a bit--and ruined it--been there-ive rebuild a few--have to be careful with them--the solenoid from the idi to the later powerstroke--they updated the post size and such on the solenoids--which mine will get before long--because the idi tended to burn the one post!!!!!!! and the cable right along with it!!!!!! :D :D
olsen726
