Dsl_Dog_Treat
Ok,
So Mater has put me to right to the brink of self destructing. This project has been nothing less than difficult the entire way from start to almost completion.
Well tonights story is this.
Fighting the front leaf springs half the day between 2 trucks only to find that my old 85 has the rearched spring set on it to find that there's a different bracket to lower the front axle assembly.
Ok, no problem over 2 hours wasted getting them off.
So I have to use the ones that I got from the goat smuggler on on of our parting parties.
Got them on fairly easy then decided to call it a night after 6 hours of working on the truck.
I start Mater up and he dies. When it does, I hear this loud metal clank so I go up front to investigate and :***: the stinkin fan spun off and I hear fluid leaking. I figure that the bearing took a crap after the hours spent attempting to remove the old fan clutch assembly as it had seized up.
Nope not that. It was a nice hole punched in the 2nd radiator in the truck in a weeks time.
Now I'm fricken burnin mad. Neighbors prolly heard me after that.
So that was the radiator that I got from Trav that was his backup radiator for the E.
I've decided at this stage of the game to drain some of the coolant out and make the repair on the radiator in the truck and see if it holds. Reason being, the plow brackets really make it impossible to get the radiator drained without loosing half the coolant, while working around the plow assembly. That and I'm just getting plain fed up at trying to get this truck together before it really starts to snow.
Anybody ever have that type of issues with a fan coming back off after being tightened up and prolly no more than 30 minutes of run / idle time?
Ok rant done.
Ok rant done.
