Spring is here, whats your to do list on your rig?
GasFree
Earth
First, wait until snow melts. Then in May :rolleyes: steering shaft u-joint, rad support bushings, track bar bushings, sway bar bushings, LS ball joints, rear drums and shoes, fuel tank pickup tube, bed body work and related, and on and on.
Can30Diesel
Agassiz BC
For now:
Finish cleaning up the wiring
Install my new to me fuse box
Wire in the 4 lights I had on the light bar in their new homes
Find some way to time my truck.
extend the steering shaft
Fix the front body mounts
Long term
the list goes on...
bab029
LA
Tires (barf) thinking 235-85/16 instead of my 245-75/16 I have now.
Steering linkage is getting sloppy
Gauges.
Hardy41
Orange,Ma
To do list,
Install new IP
Install new injector,
Install hydro boost
Install Carrier electric fuel pump
Install R & D intake (haven't ordered yet)
Install ZF5 tranny
Lots to do and the snow is screwing up everything.
hesutton
The Anti-Anderson
Bowling Green, KY
Gotta rewire the crew cab as an electrical short nearly caused the sucker to catch fire. In the process it melted the fuse block and took out a host of the stock wiring harness.
Also want to add on-board air via a York, Rhino line the bed, and I haven't even started on the to do list for the camper.
Heath
TronDD
MA
Get the truck home from the previous owner. :D
Then hopefully it's just fluids and electric brake controller to get it set up for towing the rally car.
Tim.
madpogue
Madison, WI USA
Yeah, spring is here...
attachment.php
Hmm....
* Bunch of interior parts to reinstall
* Look for some replacement interior parts - visors, door panels, seat belt bucke
* Parking brake cables (all)
* Skid plate for front tank
* Tranny leak from rear seal (prob. have to pay a shop...)
* Manual glow plug switch
* Maybe cut the soup bowl...
* Install quick-disconnect for trickle charger
* Door/window seals
* Radio/speakers
* Taillights
* Fix the @%&*^# dent in the previously pristine '80s era aluminum topper, made by a chunk of ice sliding off the roof back in Jan
And that's just on the '85. Now on the two PSD's, there's......
vanet
Springerville, AZ
Thought I was done for awhile. Then I got in the Wheeler to run to town yesterday. And no Cruise control. So gotta tear into that and figure out what went wrong. Always something I guess.
trackspeeder
Stone crusher.
North Branford. CT
My slow work truck list. (90)
Finish the pick up bed skins..
Cab panels.
Scrap the utility bed.
King pins.
Brakes.
Tires.
If I have time change out the pimp red interior:rotflmao.
