Spring is here, whats your to do list on your rig?
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
I was traveling down the road last night and went through a puddle that basically engulfed my truck, I was driving by feel, lost total sight for about 50-75 feet.:eek: There was so much water resistance, my 3" band clamp gave way and the exhaust separated where the down pipe ends.
I got underneath there this evening to put it back together and did a little surveying. I came to the conclusion that a spring time punch list is in order. Here's what I got in a quick look over.
-Oil leaking from turbo oil supply elbow, CDR grommet, and around the turbo itself. The turbo only has about 10,000 miles on a rebuild so it should be something simple.
-Up pipes leaking, looks like around the slip joint. A new one may be in order as I have sealed it up before and it doesn't hold long term.:backoff
-Bed needs pulled to clean and paint frame, fix fuel sumps and front gauge operation.
- Fender flares need to come off to put a stop to surface rust, the paint is peeling because the flares have rubbed through it.
- New batteries
- King pins
This is much better than needing new transmissions, engines and the like but an old truck will always need something I guess. So what do y-all need to address this spring? I can't be the only one with a list of things to do to my rig.;Really
subway
be nice to the admin :D
York PA
Figure out why my truck has no balls, besides that nothing big, just pulling the bed welding in patch panals and sandblasting the frame. Guess I might have to paint it up to keep it from rusting. LOL
Just welded in a new cherry bomb tonight.
oregon96psd
Kuna, ID
Spring is here?
Had to shovel out my service truck to go to work yesterday, not quite here yet :rotflmao
Wish list
Replace ZF trans,
Install lockers front and rear...have these
diesel purge for Injectors .....gotta buy this CHECK!
Maybe replace IP if can with the rebuilt I have...
rear brakes...gotta buy this GOT NEW ONES ON SPARE DIFF LOCKER GOES IN;Sweet
inspect fronts again
cab swap and OBS front clip and body lift and paint....got all this
hydroboost ...have this
turbo install...have this
IC install ...have this
rebuild bumper for front, and rear. ...have these WORKING ON BOTH SIMULTANEOUSLY
see if rear winch is doable...have this..needs a main shaft
38 gallon rear tank gotta...gotta buy this
Carrier pump...gotta buy this
fab frame mounts for saddle mount batteries....have the material
install coolant filter....have this
install racor 500 fuel filter....have this
get aluminum wheel fixed soon
That bout sums up the wish list
Al....
PS lookin for volunteers...to assist said projects
EDIT,
PURGE DONE, Rear Brakes checked out OK on Spare DIFF, Bumpers getting worked on, and OBS cab prepping for swap too. 2013.04.02
tbrumm
Richland Center, WI
Well, let' see. This could get to be along list:
1.) Get my hydroboost put in
2.)Install my new engine wiring harness
3.Clean up the frame/underbody and repair the paint form winter's ravages
4.)Clean and repaint my rims and get my new tires put on
5.)Insulate the AC evaporator housing to get ready for hot weather
6.) And if I ever get around to - clean the interior and armorall!
Warm weather has to get here first before I can (or want) to do any of it, and tomorrow it is only gonna get as high as 19° (low tonight of around 5°)
oregon96psd
Kuna, ID
I HATE snow, so tired of working on stuff outside, in the cold, in the snow in the wind. :puke:
Sorry, kinda got side tracked.....
GOOSE
Happy IDI'er
My rims desperately need cleaning, interior gets done regularly. I also have to fix a crack in my left dash support and inspect the rear brakes so I can use the e brake again.
laserjock
Almost there...
My list is pretty simple
1.) Everything.
Seriously, goal for spring and summer is new floor and cab corners followed by pulling the bed and cleaning up the rear half and paint. Tear down the parts truck and get ready for the core support and D60 swap. Hopefully be ready for engine work this fall. ;Sweet
gatorman21218
Ashland VA
So after spending 2 years rebuilding the engine (twice), rebuilding the front axle, welding and fixing all the rust on the bed, my plan is to drive the truck.
fordf350man
Rockwood MI
some new body panels to get rid of the rust
install my new/used bed on the truck
fuel fill pipe mod
install turbo
get spicer transmission and divorced transfer case
and ride the motorcycle
Wyreth
Certifiable Noob
Las Vegas, Nv
Well here's the list of what I'm going to continue putting off:
Fix gauge wiring, possibly replace cluster w/custom
Continue cleaning (I really wish there was a hot tank big enough I could just drop the whole truck in it)
New shocks
Pivot bushings, tie rods, idler arm.
Rear axle seals
Change gear oil in rear end.
Install DNE2
Finish molds for new glowplug boots & fab new harness.
Pull bed & fix shower heads
Russ
Idont do injectors
New Brighton PA
Change headlight, turn signals, corner lights, Install new LED cab lights, replace trailer hitch, touch up some paint, change the oil and drive drive drive.
tke395
