speedometer still not working
catbird7
PA
pic of gear on cable.
Those are the correct types. eBay. There is a couple good YouTube videos on changing the drive gears. It’s not that hard once you see how it works.
catbird7
PA
More info. Laserjock is correct, not difficult.
Cainon
Smithfield
This has to be what I'm missing. When I pulled the old cable out there was nothing attached to it. This should be attached to cable right?
This is what it looked like when I removed it.
Cainon
Smithfield
So if I dont have the original one to go off of color. How do I tell? My transmission is a 5speed and if I'm not mistaken the 85 f350 only had a 4speed? So I'm assuming it's a zf5 from a later model?
Right. Trans shouldn’t matter. It’s rear gear and tire size. I’m 3.55 with “stock height” tires. Yellow drive gear, wine driven gear puts me on the money.
Cainon
Smithfield
I think I'm 4.10 with stock tires, so going by the chart I should be same setup. Thanks
I think you are going to be the yellow drive and yellow driven gear. Think that’s what my truck was originally. It was 4.10 when I bought it.
Randy Bush
Great Falls, Mt
I thought this was the style of gear a ZF5 uses, it's what comes up when searching.
I can’t speak for a 2wd ZF. The tcase 4x Takes the ones above.
dieselmainiac
Staff online
