1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
speedometer still not working
Discussion in '6.9L IH & 7.3L IDI Diesels' started by Cainon, Oct 22, 2019.
  1. catbird7
    catbird7 Full Access Member
    1,090
    803
    Feb 15, 2011
    PA
  2. catbird7
    1,090
    803
    Feb 15, 2011
    PA
    Kizer, riphip and chillman88 like this.
  3. Randy Bush
    Randy Bush Full Access Member
    426
    235
    Jan 2, 2019
    Great Falls, Mt
    Those colors may or may not be the same as his though.
  4. catbird7
    1,090
    803
    Feb 15, 2011
    PA
    That's correct, they're only examples.
  5. laserjock
    laserjock Almost there... Supporting Member
    8,534
    2,586
    Nov 20, 2012
    Those are the correct types. eBay. There is a couple good YouTube videos on changing the drive gears. It’s not that hard once you see how it works.
  6. catbird7
    1,090
    803
    Feb 15, 2011
    PA
    More info. Laserjock is correct, not difficult.
    Kizer likes this.
  7. Cainon
    Cainon Full Access Member
    71
    17
    Sep 27, 2019
    Smithfield
  8. Cainon
    71
    17
    Sep 27, 2019
    Smithfield
    This has to be what I'm missing. When I pulled the old cable out there was nothing attached to it. This should be attached to cable right?
    This is what it looked like when I removed it.
  9. laserjock
    8,534
    2,586
    Nov 20, 2012
    Yep. That be the issue.
  10. Cainon
    71
    17
    Sep 27, 2019
    Smithfield
    So if I dont have the original one to go off of color. How do I tell? My transmission is a 5speed and if I'm not mistaken the 85 f350 only had a 4speed? So I'm assuming it's a zf5 from a later model?
  11. laserjock
    8,534
    2,586
    Nov 20, 2012
    Right. Trans shouldn’t matter. It’s rear gear and tire size. I’m 3.55 with “stock height” tires. Yellow drive gear, wine driven gear puts me on the money.
  12. Cainon
    71
    17
    Sep 27, 2019
    Smithfield
    I think I'm 4.10 with stock tires, so going by the chart I should be same setup. Thanks
  13. laserjock
    8,534
    2,586
    Nov 20, 2012
    I think you are going to be the yellow drive and yellow driven gear. Think that’s what my truck was originally. It was 4.10 when I bought it.
  14. Randy Bush
    426
    235
    Jan 2, 2019
    Great Falls, Mt
    I thought this was the style of gear a ZF5 uses, it's what comes up when searching. [​IMG]
  15. laserjock
    8,534
    2,586
    Nov 20, 2012
    I can’t speak for a 2wd ZF. The tcase 4x Takes the ones above.
Share This Page
