93blklightning
I know it seems ridiculous for me to ask a question like this, seeing all the work I've done to this truck but.... the tach has not worked since I got the truck ten years ago. I replaced the tach sensor , abs sensor, abs box and still no joy. If I drive at 65-70mph or more for an extended time the abs light will come on , and stay on until I turn the switch off and back on. The speedo works , but bounces approximately by 10 mph + and - . Now I've got something ticking while the vehicle is in motion , and stops when the truck stops. Its not loud , you have to listen close , sounds like its under the dash on the drivers side on under the cab on driver side . I've checked everything I can think of. The cruise control still works , but jumps with the speedo .like accelerates and let's off as the speedo jumps. I can't figure it out . And by the way what's this fipl? I read on here , some people check with issues like this . I'd love to fix the speedo and tach , I've even replaced the whole gauge cluster , still same problems .
Sent from my XT907 using Tapatalk
