Speed sensor locations fro Cruise controls??
metrojd
Pittsburgh,Pa
Speed sensor
The speed sensor is in the rear Diff. on top.
It runs the ABS and speed control.
Hope that is what you were looking for.
John
wgargan
Durham, NC/Chico, Ca
HA! and here i was loking around the front wheel and transmission areas.
But, i did see that sensor yesterday while under there. The one right on top in the front.....
thanks a bunch,
Will,
P.S. is that the only Speed sensor?
adrianspeeder
USAF C-17 Avionics
Air Force
Dover AFB / Harrisburg PA
This is what I've put together so far for speed sensors, also known as a VSS.
'87-'91 F-Series
Rear diff sensor: RABS
Speedo cable sensor: CC, E4OD shift strategy
Transfer case sensor: ESOF (Bronco/F-150 with automatic)
'92-'96 F-Series
Rear diff sensor: RABS, CC, E4OD or 4R70w shift strategy, PSOM (speedo)
'93-'96 Bronco
Rear diff sensor: RABS, CC, E4OD/4R70w shift strategy, PSOM (speedo)
Front rotor speed sensors: Front ABS
Transfer case sensor: ESOF (Bronco with automatic)
Adrianspeeder
truckonfire
