82F100SWB
I serviced my truck this afternoon, and replaced the injector return lines on the pass side, was the first time I've had it running with the air cleaner off for quite some time, and I noticed that it was pulling a fair bit of oil through the CDR, I had noticed my oil consumption had increased considerably since the last change, used probably a gallon and a half in 6000 miles, compared to the normal 2-3 quarts.
I pulled the CDR off, and it as far as I can tell is stuck open. I let it sit in carb cleaner for a good hour or more while I was greasing the truck et al, to no avail. Nothing is moving in that thing. I don't particularly care to swap to a RDT, but, I could if a CDR is a PITA to find.
Also, out of curosity, is there a turbo setup that leaves the CDR in the stock position and requires a new hole in the valley pan for the oil drain? There is what looks to be a 3/4" hole about 2" behind the hole for the CDR in my valley pan, all sealed up with silicone.
