Sons 93 F350 CC 4x
Hey all, been while and im on a ****** do this stuff on.
My son Colin may just stop by and I hope he's does....said drop my name....
Anywau he as I am in Canada and neefs good rear axle seals...sent me pics omg....craptasticlygooey mess.
Which is the best rear hub seal for F350 rear axle....I just cannot remember...
Thanks in advance
Al
chillman88
Central NY
catbird7
PA
Just as important, also make sure the breather tube isn't clogged. Over the years I've found them clogged by mud wasp nest on several occasions. Pull the rubber hose off and blow thru checking for blockage. While the hose is off, also verify the nipple is clear into rear housing with a pipe cleaner. Stick in the nipple like a dipstick. If it comes out wet with oil you're good to go!
laserjock
Almost there...
Al, this is the one I used. Recommend putting a thin smear of RTV on the outside of the axle housing where the inside of the seal sits as mine didn't seal very well there.
https://www.amazon.com/dp/B000IX2BCO/ref=cm_sw_r_cp_awdb_t1_iWzNEb5DX4N36
Pretty sure it's just a different brand of the same seal cozinsky shared.
This looks like what I used.
This is what I used. No issues so far. I think you can get them from NAPA but they are more expensive. Maybe not if you are having to import them.
