Something in the Works
FordGuy100
Silverton, OR
So I know this guy.....
(every great story starts like that LOL)
Working out a deal on his truck. 95 F350 CC SRW 4x4 7.3/E4OD with 220K on it. Has had some recent work done to it, and looks to be in good shape. Hopefully we can strike a deal up in the next month or two and it will be coming home to me ;Sweet
Quick question. I have a sneaking suspiscion that it has a cork gasket on the oil pan, as he said it was leaking oil from there. They say just use RTV on an IDI, same for the PSD? He also says its leaking oil from where the dipstick goes into the block, anything to look for there?
If we get it, right off the bat its getting an Auxillery cooler, gauges, straight pipe and a 6637 filter. Will stay that way for a while.
Always wanted a CC 4x4 F350!
FordGuy100
Silverton, OR
What are the factors influencing whether or not you are able to get it?
It mainly hinges on engine. He also mentioned blow by was more than normal. He is going to have his mechanic compression test it. If it has good compression it will come home. Truck is in Houston so it's to far to just go visit with my schedule. Paint isn't the best, probably due to no wax and the Texas sun.
Diesel_brad
Dunce
gilbert pa
WHo ever installed a cork gasket on the pan is an IDIOT. They use the Gray RTV just like an IDI. And the dipstick goes into the oilpan(hope the nuts are NOT stripped)
94f450sd
somewhere,ma
The leak dipstick adapter has an orings on it.normally the motor has to come out to fix it.there is a write up on doing it in the truck over at SDD.most times the big nut needs to be tightened up.
lotzagoodstuff
Carmel, IN
FordGuy100
Silverton, OR
Doesn't look to bad but defiantly not fun pushing something into the oil pan hoping it doesn't go to the bottom LOL
FordGuy100
Silverton, OR
That's if they have a gasket on the oil pan. Don't know for sure. I'm hoping it doesn't and is just leaking at the dipstick tube
FordGuy100
Silverton, OR
Cross your fingersLOL
Exactly. He said it was leaking oil at the dipstick and the oil pan....hopefully its just the dipstick leaking onto the oil pan. I dont think the motor has been pulled so I really dont think it has a gasket on the oil pan.
Cant wait to get a PSD though. As much as I love IDI's, I sure do miss my parents truck! Got to drive it some through high school while my truck was getting painted.
Since this truck needs paint, it will get the factory green my parents truck was.
