to check your vaccuum tee tap a gauge into your system. With truck running, you should achieve 20+ inches of vaccuum. Turn the truck off and it should have less then 3 inches of vaccuum leakdown in one minute. This is as per the factory manual. I was troubleshooting same system one day. Replaced master cyllinder, problem didn't go away. Found "coffee can" reserveoir was leaking. Test booster. I believe with vaccuum generated and truck off, press pedal as far as can to floor and release one time. If vaccuum goes to zero, booster is bad. Bad part #3 that day. Replaced those parts and bled the snot out of it, improvement but still had sinking pedal. The guy I was helping ran out of money and ran with it for the time being. Reading this thread, I should call him and see if he is ready to continue. I can't logically see how it would create this problem, but thr RABS has me scratching my head. I always wanted to ditch that pos and plumb a wilwood adjustable proportioning valve into the cab. Someday. Anyhow, I was able to save my buddy from buying a vaccuum pump, at least. Also, a new MC was about $7 more and had the reservoir included, money well spent as far as I'm concerned. Hope these tips can eliminate some guess work for you.
