Smokin out of intake
Cincinnati Guy
Cincinnati, Ohio
I have some smoke coming out my intake, by the glow plug on the driver side up front. I thought it was coming from the GP hole but upon further investigation its defiantly coming from the intake. Could this be the cause of my badly shaking motor? What is my course of action for repairing this?
emmer
Canada
quite frankly ,the only time I've seen that is when the motor was running backward on a cat diesel. The oil pressure should read zero also.
If this is the case, shut the motor off and restart it and watch the OP gauge and make sure you have oil pressure. When in first gear , the truck will go backward if the motor is running backward.
Actually I've seen this in GM diesels too, come too think of it.
jtate
houma,La
is it coming from where the intake seals to the head or is it coming from around the injector threads?
sassyrel
iowa
if it was a gas engine yes--diesel,no--only AIR is going into the engine there--like he said--sure it aint coming up around the injector,meaning injector loose--???? could be gp loose also--
Cincinnati Guy
Cincinnati, Ohio
Ill look again tomorrow but it sure looked like it was coming from the intake...
It is coming from the same area as the glow plugs on the drivers side up front just left of the glow plug. Wonder if I can go get a photo of it or better yet a video.
sassyrel
iowa
when its running--take the bottle of glass cleaner--and spray around the gp, and the injector. one or the other should show air bubbles--or a major leak!!!!LOL
Cincinnati Guy
Cincinnati, Ohio
I should tell you all I am getting major blowby right now. I will show a video at idle and a video of it idled up, lets see if it goes away if not at idle.
emmer
Canada
In a backward running diesel air is taken in via the exhaust and exhaust is expelled via the intake.
It rarely but sometimes occurs during a stall .............a unintentional restart happens, only the motor runs backward ;)
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I had a DT466 do this to me twice...people looked twice when the backup alarm came on and I pulled FORWARDS to get out of traffic to shut it down manually lol
emmer
Canada
LOL haha ..
Dang GE, I need a plow like yours!
jtate
houma,La
if you are having a blowby issue, if the valley pan is not sealed under the intake in that area it could push blowby out and thats what your seeing. try taking the oil fill cap off with it running and see if it stops it or if it gets less.
Cincinnati Guy
Cincinnati, Ohio
Here is a picture of where it looks like the smoke is coming from.
I do believe I may have some stuck rings causing the excessive smoke?
Here is a video of the smoke coming from the intake, you can kinda see smoke.
jtate
houma,La
have you tried running a couple treatments of auto-rx in the oil? also there is some oil treatment that frees up rings and breaks down sludge in the engine at autozone. its called RISLONE its in a yellow bottle and its about a 1/4 of the price of auto-rx. i believe in both of them for freeing up rings and it'll clean up the internals so if you ever decide to rebuild and on my 6.9 it gave me alot more oil pressure.
Jake S.
clueless...
Taylors Falls, MN
I would bet that the valley pan is not sealing somewhere around there, and the blowby is getting pushed though. Can't tell though with all that snow coming down. -lmao
