IDIn_It
That's where the glow plug wires go on the relay. And that black wire is the ground for the controller.
For the micro pump, where did u mount it on the frame rails? Closest to the front or rear by the tanks?In my electric fuel pump thread in tech section that's covered you grind the plate not the block BTW
Hahaha I know right.its about time!![]()
mounted it after FSV on frame so I could get away with on pump.For the micro pump, where did u mount it on the frame rails? Closest to the front or rear by the tanks?
