If you are talking about the one on one of the front wheel 4wd knuckles, yes.
One other overlooked cause of slop is the steering shaft itself. There is a plastic sleeve and a metal clip inside there that can all apart.
the shaft between the firewall and steering gearbox. If you look at it you can see its a two piece slip shaft and the parts that break are inside that shaft.where is this at ?
