cason234
Hello old Ford enthusiasts! I am the proud owner of a 1990 F250 4x4 5 speed with 7.3 NA diesel. Not sure how many miles (I suspect 205,000). The steering column is pretty sloppy, and I'm looking to this group for suggestion. I'm referring to the UP / DOWN play in the steering wheel. You can move it up / down almost 2". The play in the steering assembly is 'normal', but its the floppy column I'd like to address. Any suggestions for repair? Is it a bearing? Should I look for a different steering column? Any help will be appreciated! Thanks in advance for your help and recommendations!
PS: Not totally new to diesel Fords..... I also have a 95 Crew Cab PSD 2wd with 180,000 miles. I just rebuilt the TTB front end, including RedHead Steering box, new ball joints, new linkages, and new shocks.... nice improvement.
