1991 F350. 7.3 n/a with E4OD.
Previous owner stated the transmission was rebuilt. No way to confirm.
I have noticed just a slight shift flare mostly at part throttle and I believe 3-4. Maybe 2-3.
My first inclination is to pull the tranny and install a tugger kit. But before I do, is there any chance this could be cured by a FIPL adjustment? I checked the FIPL this summer. It is not original and it was set at 1.2 volts at idle and swept up smoothly with throttle.
I purchased the truck late last summer and have not yet towed heavy. But this spring I'll be needing to tow 10k lbs on the weekends. I'm concerned the transmission problem will be magnified when towing but I have no data to back this up.
