simple tcase question
dulcevendetta
placerville,ca
hey all, i have a 89' f250 diesel with a BW1356 transfer case bolted to a ZF5 was just wondering is the tranny oil shared with the tcase? or does it have it's own oil supply?
jperecko
Diesel Ape
Boonies of SoCal
My specialty is a T19 with a 1345 transfer case but the 2 t-cases are similar and the answer is no. There is an oil seal on the input shaft. I assume similar for yours.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
the fill plug for a 1356 is on the rear of the t-case. You guys are right though, the transmission and t case are both sealed units and use their own oils, they do not share. I used to run transmission flud in my old 1356, what is best to run in them?
6 Nebraska IDIs
I think you're supposed to use ATF in the transfer case, but its been so long I can't remember.
adam g
Emporia Ks
Atf in both the t case and the zf5. I have had a few 5spds that were hard shifting and the owners didn't know why. They had put 90 weight in.
Dsl_Dog_Treat
Decatur,MI
Yup separate oil sources, unless a seal goes bad between the 2. Mercon III.
If ya separate the two in the truck, you'll think they share it tho.cookoo
trackspeeder
Stone crusher.
North Branford. CT
Any Mercon/Dexron or Mercon V will work. You could spend a couple bucks more and use synthetics. Mobil 1 is what I feed all my T cases.:D
