Silly Turbo Q?
argve
Resident Fruitcake
Gwynneville, Indiana
Last time I checked a turbo was a turbo be it diesel or gas powered engine... so by that token Yes it would work but you would need to size the turbo's accordingly - now for how to do that... That one is beyond my gasp because I don't know the math involved for selecting the correct turbo but I'm sure someone could come up with it.
riphip
Memphis, TN.
You could then have dual exhaust + dual turbos. The turbo guru (Huff) stated at one time on the other site that if you ran an electric fuel pump, you could use the manual pump to return the oil from the twins to your sump ensuring adequate flow.
John Haggerty
Birth Certificate
New Windsor, MD
That's easy,
[2^3*22/7+13.987/7*35^5]^2=BS
:rotflmao
Anymore more easy mathamatical problems?
stiesel
upper, MI
Camarogenius said:
What if I got two turbos off of gasser motors and set them up as twins?
i say go for it. but since you have eight cylinders why stop at two turbos. :rotflmao
82fordtruck
NE Kansas
Jeff - want another engine - I just found one with a banks on it at a junkyard. I can bring it up to you if you want.
Mr_Roboto
Elyria, near Cleveland Ohio
Hmmm, screw the twin turbos. Do a twin engine setup!!
Way back when, I was in classes for the tire chain I worked in. A fellow there told me a story about how he put two turbo 4's in some ricer, since a V8 wouldn't fit... Said it was the fastest thing on the road, and even the cops wouldn't chase him because it was so fast........
I think he was smoking something, and not his car's tires..
