BP6.9
hey i have a set of spare heads i wanted to have rebuilt but their warped just a little bit, can i have them saved to fix the problem? or should i chunk them for scrap?
I have yet to find any reasons for these specs. We run a hydraulic needle bearing roller lifter so its not like we have a solid lifter. Problem with finding a shop that can mill the heads and the precups at the same time is a tuff one. The precup material is so much harder so the cutting tool must be differant than the norm for cast iron... BTW the precups have a tollerance in the heads too. They must be +or _ .0025 of the head surface. That means they can be recessed or stick out of the heads by 2.5 thousands. A member had his 3.5 out and the head gaskets could not seal it off and coolant leaked up the head studs...which is best in my opinon.
so i can have em shaved? because the guy i was going to take em to has the equipmwnt to do it i just wanted to make sure it was possible before i started sinking money into it
