Sending units
Brutis
Work in Progress
Niagara, Wisconsin
The fuel gauges have never worked on my truck and there is a leak from the pickup from my front tank. Now that I have a parts beast I thought about snatching the sending units ect... from the 1994 parts truck and swapping it onto my 1990. Are they the same parts or did things change in 4 years?
Diesel JD
Gainesville, FL
Pretty sure anything 87 and later will work, so yeah I'd give it a try at least. While you have them out take a multimeter and move the arm up and down and see what happens. You should have an ohm range of 158-16 on the newer (87 and later) sending units. Also check the floats and make sure they are not leaking or saturated with diesel.
plywood
Recovered N/A
Portland Oregon
I just looked into this recently and to my recollection the sending units followed the body style years pretty closely.
I didn't however find one comprehensive source of info or keep organized notes.:dunno
Diesel JD
Gainesville, FL
Yeah the 87 and earlier are 78 ohms empty and 10 full. I know the range is 158-16 on the newer 87 and later senders, don't know which direction they go...more resistance full or more empty. Only know for sure they won't interchange.
Diesel_brad
Dunce
gilbert pa
Great. Guess i'll have to use 86 sending units when i go over to the powerstroke:mad:
Jake S.
clueless...
Taylors Falls, MN
trucks:
80-86 are high ohms empty, low ohms full
87-up are low ohms empty, high ohms full
vans:
at least till 1990 they are the old style, I don't know too much about them, but when the clusters switched to the newer style, they went to the new truck style.
jwalterus
Made in America
Garrison, ND
this is some good info to have, something I never thought of, picked up some aftermarket fuel level gauges so I can monitor both tanks, and wouldn't you know, when I just checked em, they won't work on my truck
m2rtin
