Remove underhood liner - will it be much noisy-er in cab?
mankypro
Learning Slowly...
Boulder County, Colorado
My under hood liner has seen better days - it's sagging and such. I'm thinking about tearing it out and putting up some peel and seal or something. Until I get other insulation under there will the engine noise increase in the cab? I would think maybe outside the truck, not inside -right?
mankypro
Learning Slowly...
Took it out this afternoon and the sound is a bit tinnier that's the only difference I've noticed. It was in such bad shape it was obstructing airflow.
hheynow
the misanthrope
SF Bay Area
Regardless of what you replace it with, a sheet of hood foam or aluminum sound deadening sheets it provides three functions. 1) Keeps heat in engine bay (great for WVO & WMO) 2) Keeps hood paint from blistering ( not a problem with your truck :D ) and quiets the engine noise. I just got a new hood foam pad for my Mercedes this week. Old one was foam and would crumble to dust. It only covered 6% of the hood. Scraped the hood with a plastic scraper, lightly sanded then got 3M brand p/n 8090 Super Adhesive for hood insulation and auto trim. EXCELLENT PRODUCT :hail as well as the hood insulation.
milner351
SE Michigan
hheynow - where'd you get your hood pad for the MB?
and - does anyone know where to get one for OBS PSD trucks?
I have never had one and I would like to do anything that can make the truck quieter.... I have used the foil faced black rubber type self adhesive stuff inside boat engine covers with good results - but i'm not sure how it would last on a truck hood with all the heat and vibration....
Big Bear
