Rearends?
83ford
ford diesel baby
calico rock.arkansas.us
Ok so I screwed the rear end up bad in my 96 itll roll and then just stop the truck in nuetral or driving luckly I was doin about 5 mph in the field when it started but anyway I have a 85 with 3:55's im pretty sure and mine has 3:55's I know I can't put the axle under it because I won't have a speedometer well I could but I wanna know how fast im goin but can I take the guts outta the 85 axle and stuck in the 95 axle
Sent from my Iphone using Tapatalk
sounds like your pinion gear and nut are loose.
pull driveshaft and see if the nut is loose.
its cheaper to buy another rearend.
lotzagoodstuff
Carmel, IN
+1 on checking the pinion nut, they are notorious for loosening, you can try tightening it but keep in mind that anything you chipped off the ring & pinion are now in your rear axle. The spider gears are usually pretty good at pulverizing loose pieces which will intern get into any bearings/seals. Unless you catch a catastrophic failure immediately, or you have a rare/original axle you want to keep for some reason, I am a big fan of scrapping a metal contaminated unit.
Which brings me to Idiot's second very valid point: there's a ton of good used rearends out there that will fit your rig for cheap. Also bear in mind that if you choose to repair your ring & pinion, there's a short and long pinion version, which adds a 50/50 chance of getting the incorrect version.
I see used Sterling's go for a couple hundred bucks all the time here in Illinois, which is about what a R&P is going to cost you. Go find yourself a good used unit and swap the whole thing. You'll likely end up with a newer/lower mileage version, you can (and should) check the condition and ratio, and you'll end up with a bunch of extra brake hardware, which could be handy down the road.
Good luck whichever way you end up choosing.
i just had this similuar issue with my 10.5.
purchased a used diff for 400 bux.
but didnt open it up like i should have.
got it home and it was an open diff.
cost me 400 to swap my LSD into the new housing.
then after i got it fixed, i blew a head gasket :(
83ford
ford diesel baby
Well I had just had the driveshaft and yoke off to fix it and got it back on and busted the axle 4 hours later.but can all the stuff from the 85 transfer over to the 96 and its a zf5
83ford
ford diesel baby
And the axle is toast it locked up on me bringin it home my buddy was pullin me sideways down the road luckly there's not much traffic on my road lol
lotzagoodstuff
Carmel, IN
I believe that you are going to find a shorter pinion in the 85 guts than your 96, I believe the switch for the 10.25 sterling was 1992. For what it's worth, the longer spline is the tougher of the two, so you'll be downgrading.
Desperate times call for desperate actions, but if you have a little time I'd swap the whole differential.
Good luck.
Personally, I would just grab one from a junkyard. I know you got a lot going on and everything.
You almost might as well get a SD disc brake axle.
that calls for a rim change.
83ford
ford diesel baby
Could I just put the 85 axle under for now so I can still move it till I can fix the 96 axle
83ford
ford diesel baby
Man this craps bout to kill me I guess I just lost the transfercase or 4th gear in my 86 comin home tonight idk it only did it in 4th but I was almost to my house so I just limped it home so now it comes down to which is cheeper to fix.i should have all the parts to fix either of them but I think the 96 will be easier but it's not even licensed yet.so will the yoke in the 96 axle fit the 85 axle so I can keep my new ujoint and driveshaft or am I not gonna be able ti
