Thank You, I was replacing the rws on one side and figured I would do both, now I had to buy napa seals since the ford where order only and I need the truck so against My will I had to pass on the motorcraft and use some napa seals hope they hold half the time the original seals did
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I also have this noise I can hear after I pull the trailer (17-20k pounds combined weight) and some times while pulling I think it comes from the front wheels or one of them. When I did the front bearings I read somewhere to tight the bearing nut hand tight but I thought about it and changed My mind I think this is where this whistle comes from (is not the brakes) so I give the nut a little snug with the breaker bar not much but enough I think. Is there a toque # for this too?
