FordGuy100
Someone wanna dig up some old posts about rear disk brake conversion for our trucks. Also is this sterling axles or Dana axles? I'm just a wondering whats involved
I like the idea of running the Ford dual piston calipers over running a single piston gm style caliper.
http://www.fordmann.com/F350.rear_disc_brakes.htm
.That's what I like about my 91 F-Super duty. It already has the Hydro-boost and rear disc brakes.![]()
it's not as easy as you would hope.So what all is required for the Dana 70 swap?
even the guy in the link had a fair amount of fab work.
the offsets between the drum versus disc rears is significant enough where you will have to mover the mounting collar. the second part is the disc brake rear mount bracket uses 5 bolts instead.
