Oh I know. I've replaced the master cylinder. Flushing the fluid is next.
Flushing the fluid did wonders for my pedal feel. I would do it as soon as you can as the contaminants will start deteriorating the new parts. It would be good to get another 20 yrs out of the new ones.
Also need to lube the front slide pins.
Another "I do it every time I work on the brakes" item. Don't forget to clean them good before lubing. I had lube build up on one of my vehicles and they got gummy and didin't work very well until I cleaned them good w/Brakekleen.
Since you seem pretty knowledgeable, what's the best procedure for adjusting the parking brake?
Mine goes straight to the floor and barely does anything. I know I need to adjust the shoes some more. But I don't have access to a strong enough jack to get a tire off the ground. My 2 ton floor jack won't budge it. Lol
Adjust them as firehawk says and then the self adjusters will work. They need to be adjusted properly for the self adjusters to work at all. The parking brake should not be adjusted until the rear brakes are properly adjusted as they work together to keep the truck stopped (i.e., if the parking brake is to tight, the brakes will not adjust properly.) When everything is working and adjusted properly, you should be able to backup, hit the brakes until stopped then repeat a couple of times and the brakes will self adjust. If they don't, something is either out of place, installed incorrectly, gummed up, or inop.
