So is Noalox the best for all the connectors?
I don't know if it's the absoloute best conductive grease, but it's a real good one. I've been using it for years.
It's rated for 20 years service life in high temp environment, so connections dont dry out and oxidize.
Only time you use dielectric grease is on spark plug wire ends where you don't want high current leaking out. If you ever use it on sensor plugs , ( which unfortunately, mechanics do all the time ) somewhere down the line there will be false readings and module failures, and on computerized vehicles , cascading electronic failures through the entire system.
