WrickM
with the way the power curve starts dropping off at the higher rpms I am not sure it owuld be worth it to push the motor that hard. Still neet to see though.
My thoughts exactly.
All of the trucks that were dyno'ed at the rally were all seeing peak HP around 2250 rpms.
Peak hp is up around 3300 rpm.... Peak torque is around 1800 to 2000 rpm. So says my Navistar shop manual...
One thing I was seeing while I was messing with the turbo maps on the Moose thread...was that it seemed like all the good turbo's would work perfect up to 3300rpm's, but it started to go out of efficiency when the rpm's went above 3500rpm's. Boost would stay the same number, its just the turbo has to put out more lbs/minute and cfm to feed the engine with the same amount of air per stroke. This pushed the turbo out of its efficiency range, bringing down the volumetric efficiency, and bringing up the heat output of the turbo.
So effectivly pushing rpm's that high is acting like spinning a turbo past its efficiency range, it will only superheat the air, and loose you more power.
unless you use a turbo that doesnt go out of its effciency range then it shouldnt super heat the air
