saw two kinda loose connections on the return lines, repaired those, gave all the lines a tug test, seems good. replaced shrader valve, ran the e pump, purged air out of the filter head, same thing, crank crank crank, stopo, reglow for 5 seconds, crank crank takes off like air intrusion, then within a second settles into a normal smooth cold idle.
shut it off, within a minute go check the shrader valve with the pump off, hear a hiss of air. am i still getting drainback? If i recall correctly when I had my old mechanical pump, with the truck off i was still able to press the shrader and get a dribble of fuel out of it? it definitely starts like air intrusion..
