real low idle
Cincinnati Guy
Cincinnati, Ohio
I noticed the past few days that sometimes my truck idles real low, my RPM shows about 400 RPM at idle. It is usually about 500-700 RM at idle. I also noticed my high idle didnt kick on. What could be wrong? Seems to run fine but just the idle problem.
Do you press the go pedal down to set the Hi idle when starting? How about a loose connection on the cold advance solenoid ? Bad contacts on the motor temp sensor under the t'stat housing ? That powers the Hi idle solenoid until motor temp reaches 112* . Hi idle should be around 900 - 1000 RPM, Lo idle at 650.
Exekiel69
This may not be the problem, but a clogged fuel return line can lower rpms till it stops the engine.
Staff online
