Rag Joint Replaced
rickrat
Coeburn, Va.
Truck was wandering all over the road. I replaced the rag joint, problem fixed.
Only thing that sucked is that Ford press fit the original joint. Had to remove the steering linkage and drill it out. Then I ended up having to modify another rag joint to work.
All is well now though! If anyone else has steering slop, its well worth it to check the rag joint. Even though mine looked good, it had "softened" up enough that it flexed like crazy resulting in play.
f-two-fiddy
Duluth, Mn.
FYI the older (83-87) fiber rag joints can be eliminated by using a newer style (88-96) rubber joint. Just by swapping out the intermidiate steering shaft.
diesel4me2
Camping is more importanter!
northern illinois
just replaced mine with a borgson. WOW what a difference, no more disconnected feeling for me. it uses u-joints instead of the rag/rubber discs
chris
Morgoon
Thunder Bay ON
Just wondering what the borg shaft cost you..I had an ol' dodge I wanted to put one of those in for a long time...
f-two-fiddy
Duluth, Mn.
Yeah but considerng that they're 10 years newer than the fiber ones....
The Fiber rag joint is prolly more suseptable to oil soaking.
