Radiator mount threaded washer
ComatoseLlama
MI
Hello,
I'm almost done swapping my engine but have come to an unexpected issue. I snapped the core support bolts when I took off the core support because I figured it was an easily replaceable part but from what I've seen it's pretty pricey. Is there a source on the threaded washer? LMC doesn't seem to list it
I can re use everything else until I can cough up the dough for a new bushing set. From what I have read on the forum, many go with polyurethane bushings. I can't tell if these require the threaded washer piece however. Will I need that washer if I go with poly bushings?
Thanks,
CL
WarNose
Bay Area, CA
I'm pretty sure I bought all of the parts through LMC. They had a diagram with listed part numbers. It was pretty pricey though. When I get home I'll see if I have the receipt with the part number.
Lance
