mjs2011
I recently had contamination issues with my HIH wvo lines where they came apart and wvo and coolant were mixing. Long story short, I got coolant in the wvo tank and wvo in the rad. That issue has since been fixed. But it brings me to the point of this post. We took the rad out and were doing flushes and decided to take it to the shop in town to be boiled/rodded. In the process, it sprung a leak. So I opted to get a new radiator. I purchases a 3 row aluminum from Champion radiators. It cost me 290 shipped. I must say that the build quality seems impressive. So far I have but one complaint. The cap that was included with the rad says 1.1. I seem to recall from another thread that that means 1.1 bar, which equates to about 16 psi. Now my old radiator cap was 13 psi, but we didn't think much of it. That is until I noticed a water leak. It is dripping right off the pulleys in the front of the engine, so we think it is the water pump seal. Now I am inclined to think that this is the radiator cap causing this, since it would leak only when the system got hot, thus pressured up, and if you were to open the cap and relieve pressure, the leaking would slow down substantially. However, it still leaked under 13 psi too, so now I am going to be installing a new water pump.
Just a heads up, especially with older vehicles and neglected cooling systems, be aware of the radiator cap that you are using, as a sudden spike in pressure could cause headaches.
Sent from my SCH-I535 using Tapatalk 4
