Woa, few things to consider.
You will likely need the front drive shaft for the 60 and the transfer case front output yoke as well!
Then you will want to ensure if you do indeed have said 4.10
First check out the door tag near the striker on cab there will be an axle code for example H9 means 3.55 posi, just google Ford axle code XX and xx = what your code is, then check out the links till you find out what it is.
Do the same for the donor axle, you may have a posi and the donor may be open or visa versa...
If you want and don't have a posi...get it...
Just some food for thought!
Also you can always open our rear axle and see iwhat the ring gear is stamped for say 44/10 or 44/11 as an example that tells you 100 percent the ratio...just divide lil number into big..
Also you will be able to verify if you have a posi or not!
JM2CW
