Quick Question
geno8769
Southeast Louisiana
Are the body, bed, and front end mounts the same betweeen F250's and F150's? Can I put a 95 F150 body on a 92 F250 Chassis??
How hard is it to move the correct wiring from the 92 Cab to the 95 Cab?
Any input would be greatly appreciated.
If all the mounts are correct the only thing that scares me a little is the wiring since I will be put the gas cab on a diesel chassis.
Thanks.
timothyr1014
chandler. az
As far as the cab swap I believe one of the guys either here or on FTE did a f150 cab swap. As far as wiring, the two routes i see would be to either splace or full wi
ring swap....personally I would get a wiring schematic for both and splice (if you are decent with a soldering iron)
Sycostang67
Scooty Puff Junior
Kuna, ID
The mounts are all the same. I used a 95 F-150 front clip and a 1993 F-350 bed on a 1985 F-250 frame.
Frames are almost the same too in my respects. But yes, the cab mounts are identical, all the way to the rivets.
Frames are almost the same too in many respects. But yes, the cab mounts are identical, all the way to the rivets.
