Question about diesel knocks
rustygold
conway Arkansas
I havent tore into my motor but i have a knock. It only started a week after i put my trubo on or that when i noticed it. In only pushing 6psi and a did turn it up some runs great but im wondering if by putting the turbo on it needs to be retimed? If not i guess ill be pulling the more would like to freashen it up anyway. Will be doing some upgrades if i can.
nostrokes
Colorado
If you can post a video that would help a lot.
Did you turn up the fuel screw?
rustygold
conway Arkansas
Its hard to hear the knock on camera and i turn it up two flats. Anymore seams to be to much rolling coal on acceleration just alittle.
nostrokes
Colorado
Video would still be helpful..
My banks system says 1 flat. What system did you put on it?
Could be a bad valve that decided it had enough, bad lifter, bad cam, bad injector.....
rustygold
conway Arkansas
Ill try to load it up. I did do a injector test crack the line the noise went away but thats on all the injectors one by one.
nostrokes
Colorado
So you cracked/tightned them one by one and the noise went away with all of them??
Sounds like maybe your injectors can't handle the pump being turned up..
That won't make it knock........
It won't need retimed for the turbo persay, but it is totally possible you already needed retimed....
rustygold
conway Arkansas
Ill check it aint nothing to time it. Jasper how offen you need to the truck?
rustygold
conway Arkansas
Its sounds louder by ear then phone. Either or i might roll in bearings and rings do want to control my blow by better. Its not bad but i like little to non. But cant get the video to load on tapetalk.
nostrokes
Colorado
Hmmm sounds just like mine, except I have more valve train noise...
Mine comes and goes, some days it's really predominant and others I don't hear it at all. Lots of blowby too but doesn't use a ton of oil, leaks more then uses I think..
Pretty sure I've got a burned valve causing mine as one hole is cooler than the others.
Bradz
