dshane
can someone please tell me if i got #1 at tdc on compression stroke the dowell pin on pump should be at 5 o clock
is that correct?
thank you
is that correct?
thank you
SEARCH is your friend...and this comes up as the most recent threadcan someone please tell me if i got #1 at tdc on compression stroke the dowell pin on pump should be at 5 o clock
is that correct?
thank you
The Image in POST 7 shows the relationship very very clear, 4 or 5 o clock is subjective to the person saying it...that post does not say where the dowell pin is at 4 or 5 o clock
