rattleonby
Hello fellow OB members and idi owners!!
I have a recent issue with my truck that has me scratching my head just a tad. Now the goods...
Symptom:
My truck will stall if i abruptly let off the skinny pedal at an idling standstill (Like if you were to test for bad motor mounts) but it will do it regardless if you hold the brake pedal or not. It will not do it if im rolling over lets say 10 mph.
I've ruled out the pickup pump fuel pressure at the filter head, pressure is fine. Fuel filter is only 1k old and has had only diesel ran through it.
It will do it cold or warmed up but not on fast idle obviously because of the raised idle speed.
I almost thought maaaybe a dragging torque converter but it will also do it in neutral or park. If it was that most of the time i see that the truck will stall as soon as you put it in gear....So thats ruled out.
I AM running additive in the truck to maybe see if it was a fuel quality issue or possibly gelling. It has been getting down to 20-30 degrees here in PA. It does it on both tanks also so its not a shower head or selector valve issue nor is it fuel quality....So thats also ruled out.
I'm left staring at the possibility of maybe the idle circuit on the injection pump?? Or maybe someone has seen the engine torquing slightly pulling on the engine harness causing the shutoff solenoid to lose its power??
Just wanted to see if anyone here has experienced this problem that im having....Other than that the truck runs great and has all its power..
Thanks, Merlin
Symptom:
Thanks, Merlin
