Pump adjustment
Fordfarmer123
Westfield
Turned Down my pump like 4 flats, it seemed like it was turned all the way up.. is there a way I can get it close to the original settings?
It's already producing less smoke at idle. What happens if I turn it down to far?
Sadly you can turn them down too much. I did that to my first Moose pump. Then it developed the heat soak hard start issue. So I purchased another Moose thinking I may have damaged mine but..Mel told me some time later after he worked on it that I had turned down the fuel so much it was below what a non turbo pump was putting out.
