Classicfordguy
Oh yea, the machine shop I use is actually called "The Machine Shop" run by an old guy named Joe. They are off of Orange avenue on Drennon, the number is 407 851 4050.
-Rob
-Rob
Yeah the sealed power pistons are hyperteutic. Dave Spounagle says that the OEM Mahle pistons are also hypertuetiuc.
you are correct, they do have a high silicone content which makes for a more durable +cast+ piston. I'm not concerned by the method used to (pack) it in there. just the fact that it is a cast piston. which would you suspect stresses a piston more, nitrous in a gasser or diesel? if there even close to a toss up, wouldn't you just naturally default to a forged piston? if he really does have cast pistons in there now, wouldn't you suspect ,that may be one of the factors for the piston failure?From what I have gathered over the past year or two, cast pistons are pretty standard in old engines and can't hold up to much more than standard use. Hypereutectic pistons have a high silicone content to make them more durable. From what I read metals have a eutectic point, the point at which no more of that metal can easily be added to the alloy. Supposedly silicone has a eutectic point of 12% and hypereutectic pistons have a silicone content of 16%-19% so they must use some process to pack it in there and make a durable piston. They are supposed to be good for street/strip use but not nitrous oxide use. For nitrous us forged pistons are much better.
-I could be wrong, if so someone correct me.
-Rob
BE ABSOLUTELY RELIGIOUS in the untorque sequence of your head bolts. it is reverse of the torque sequence. !/4 turn on each bolt. Otherwise you will have cracked heads.
does this comment about how to remove head bolts apply to all diesel heads or just the 6.9/7.3?
i had an old 6.2 that i tore down for parts and i did not remove the heads this way - i just took the bolts off. How could i tell if they are cracked from doing this? Is it really likely that they are cracked?
thanks,
paul
