Classicfordguy
Well the engine is down to a bare block, just finished. Found my knocking noise, the back piston on the driver side was sloppy and loose in the cylinder. When I pulled the piston the oil ring was in pieces (some of which I found in the oil pan) and the middled ring was in two pieces. I didn't read your posts in time and I already took the heads off, sure hope I didn't crack them.
I've been told I need new studs for sure but do I realy need to spend $350 on studs? I'm a broke college student, is there a way to get cheaper ones, I'm not trying to build any massive hp and never over 10lbs of boost.
I'm planning on heading to a machine shop in the morning, I assume the one sloppy cylinder will need to be bored and sleeved. I imagine they will check to see if any other cylinders need to be done?
Since I have the whole thing down to the block, what things do I realy need to do? I can have only one cylinder sleeved right? Just sleeve the one and buy a new piston top and rings for it? I assume I can keep the same cam bearings, rod bearings and main bearings? Is there a need to do new freeze plugs? if so, is that something I would do or the machine shop?
How can I post some pics? I have never tried.
Thank you guys so much for all the help, I still don't know if there is any way to have this back together in a week but im going to try. Im sure I'll have more questions in the morning, its 2:30 am and im finaly done for the day.
-Rob
-Rob
