PSA: Check/repair your differential breather!
BDCarrillo
Abilene TX
PUBLIC SERVICE ANNOUNCEMENT:
Check the breather vent on your differential. On every truck I've had (5x so far), that vent has been clogged. It killed the pinion seal and bearings on my '09, caused the '91 to dribble out of the axle hub seal, and the '92 to leak out of the pinion seal. Any blockage of that vent causes pressure to build up until it finds the easiest way out, which is usually a seal that's a pain to replace.
Here it is, on the passenger side of your rear differential... the hose should run up to a clip on the frame:
(photo from guzzle7pt3.com)
Pic from youtube of a Sterling axle, and what can happen when that vent is clogged.
Carnage!
THE $10 FIX:
- 2 feet of 5/16 hose
- 5/16 inlet carb fuel filter
Attach hose to fitting, and carb fuel filter to the other end of the hose. Use your factory clip or zip ties to attach to the frame rail, ensuring the hose has slack for suspension movement.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
I walk around junk yards. Under the hoods of Chevy 4x4 trucks(88-up) they have these nice little caps on the firewall and core support for the vents on front axle and trans/tcase
