76ford466
Another member
We'll after taking a break on my white crew cab 92 f350 project I'm back. In full tilt too lol. It was originally a 460 auto truck. Which was ok but gas millage sucked. I pulled my 7.3 and zf5 form my 88 250. Just a run down on what's went on so far...engine completely rebuilt 0.030 over mahle 0.020 shorter coated pistons and rings, king bearings, reground cam 206 grind from delta cams. New push rods new oil pump, new comp 910 springs. New stainless valves, ported both intake and ex on the heads myself set up the valve springs and built the engine myself. Balanced connecting rods and pistons. Arp head studs, painted it all red and aluminum. New full circle Kevlar clutch disk with one side a puck Kevlar metallic. Single mass flywheel. Turbo from a 2004 5.9 cummins. He351cw. Had to make the adapter to make it fit. But it's the same t3 flange as the stock ats mount. Got the up pipe form a member here original ford 7.3 piece. Goin to intercooler it. Has Mel's moose mister II injectors. Still not got the pump yet. Just got the down pipe fabled up this evening. All stainless exhaust 3" to 4" powerstroke diamond eye kit. I installed new black carpet with sound deadened under it. Put a diesel cluster in it. Ordered me some nice 07 f150 lariat seats for it. Buckets for the front bench rear.
