Problems!!
dyoung14
Is getting worn out
spencer,tn
Ok well i finally drove my new truck down the road and we gots problems and i need help. Well idling there is a little smoke bluish/gray i just figured it was normal since the truck had set a while, well the thing covered the hole road in blue/gray smoke and im not sure what to start, but i changed the cdr and it didnt help, the guy said the ip had been rebuilt by some one he knew so im kinda thinking that the guy might have f'd the pump up, what do yall think?
ameristar1
The One Blue Thing
Steger, Illinois
C'mon man, you killed her already?! Naw, just kidding, but have the injectors been done? Does it smell like raw, unburnt fuel? Maybe run some cleaner through it and see if it clears up. Elsewise, time to do the compression check to see if the cylinders are weak. Timing could be off. Does it basically run good except for the smoke?
dyoung14
Is getting worn out
spencer,tn
I guess its unbured fuel smell not really sure what it exactly smells like, i pulled 2 injectors out of it and one of them was really wet, so i changed it with a unknown injector i have laying around, i figured when i got the chance i would check the rest and see if there anymore that leak, but yes the truck runs real good other than the huge cloud of smoke and it has plenty of power i even think it has more than my white truck or my dads 7.3
cornbinder 84
Goat Rancher
Jonesville, Virginia
My truck did that when I first got it and I finished filling the tank up with fresh fuel and put in 2 bottles Diesel Kleen. After about two days of driving it almost quit smoking completely at idle, and now only smokes coal black under full throttle instead of the gray diesel smelling smoke. My truck had been sitting for a year when I got it. I know it needs new injectors, but the big dose of fuel treatment helped it alot.
dyoung14
Is getting worn out
spencer,tn
ok well i guess i will try it in mine and see what happens
