Here is the connector. I have numbered each contact. Even on the built in 4-flat connector.
1 is running lights.
2 is left turn signal and stop.
3 is ground.
4 is electric brakes.
5 is right turn and stop.
6 is constant power.
7 is right turn and stop.
8 is left turn and stop.
9 is running lights.
10 is ground
Continuity is a handy tool for quick checking. But it can report "connected" when there is not a good enough connection to keep a brake light on as well as showing continuity _through_ the brake/turn light as you are reporting.The results...
Continuity tests with the truck turned off, all lights off, etc...
NO continuity between 5 and anything else.
I want to be sure I understand. If the tail lights are on, the right trailer lights up. Activate right turn and the trailer right tail light turns off:Test with analog test light.
With brakes on... #s 2 and 8 light up. Not # 5
Every light on the truck itself works exactly as it should. Absolutely no problems there.
This testing cuts out the trailer. But remember that on the trailer, any time that right turn, or stop light is activated, the complete light on the right side, turns off. No dimming no brightening, no blinking. It just turns off.
...running lights come on, on the trailer just fine, but that right light gets interrupted when the right turn, or brakes, or hazard are turned on.
So, the problem is isolated to the wiring going to the right turn/stop contact in the connector.
Maybe it's a ground problem. Maybe the wire is grounded out somehow. I don't know.
Instead, my gut is telling me that it is the lack of ground that is the problem. When that circuit is activated, there is no ground for it to go to. and it gets fed back through the wiring, instead. Which actually turns off the light.
But that doesn't seem to make sense either. It seems to me that the lights themselves are providing a ground.
All power and no ground (return) will produce the same symptoms.If some sort of positive signal made it through, the light should operate.
But how is it that opening that circuit results in that light essentially getting all ground, and no power?
I came up with a wiring that would produce your symptoms. But I don't know how it could exist with the truck and trailer connector. It involves the "return" for the right turn/tail lamp being connected to #5 and the "hot" for the right turn/tail lamp being disconnected.When neither ground nor power are available from that contact?
I AM sure that the problem is between the contact that you can see in the pic, (#5), and the wiring on the truck. I really don't think it's the truck wiring. Or the trailer wiring. It's what runs between the truck wiring, and that contact...
Is it broken?
Is it grounded out?
Is it wired up to the wrong thing?
Here's another twist in the plot.
The only extra wiring that I know of in the circuit, is a third brake light that I wired in, myself.
But... I had to have a signal from the brake light. So, I had to tie into the truck wiring for that signal.
The 3rd brake light only comes on with the brakes. It doesn't operate when either turn signal, or the hazard lights operate. So I don't think I somehow got tied into the right turn signal wiring.
That is for reverse lights. Not used on the trailer. Not even connected to anything on the truck contact.You missed the center contact on the 7-pole round.
I was using continuity ONLY for a secondary 'feedback' as it were. Relying mostly on the analog light.Continuity is a handy tool for quick checking. But it can report "connected" when there is not a good enough connection to keep a brake light on as well as showing continuity _through_ the brake/turn light as you are reporting.
It's too late to make these tests. But I wish I had. It would have added to the clues the fun and the challenge.What about 5 to 7. Those _should_ be connected together...
Etc...
Yup.Sometimes is better to think of the system with ground being it's own wire rather than chassis. But this is a puzzler either way.
I would expect that to effect both left and right..
Right on Salahdoor!!! I'm 41 this year, and most of the people my age stare at me like I'm an idiot because my newest vehicle is a 1990 and I buy broke stuff make it work and sell it to them! For profit!!! Nothing like going Columbo on a mechanical or electrical problem. Keep on truckin' BRO! I've really digged reading this mystery novel of a thread, can't wait to hear who killed the guy. He deserved it, though. I mean acting like a Dodge with weird electrical problems!Ok, I got it fixed, but I'll answer a question or two. Then explain what happened after...
Yup.
This is in reference to my third brake light, and I agree:
Ok, I'll show the problem and solution in the next post. But first I want to say something.
Yall are all free to laugh at me now. I don't mind.
The solution was very simple. The problem was very easy to locate. It took maybe 5 minutes of being under the truck, to find the problem, and another 15 or so to figure out the solution, and make the fix.
I could have just done that in the first place. Yes it seems like I wasted a bunch of time. But if I had it to do all over again, I would do it the very same way.
The reason why is....... Just as you have to exercise your muscles or they will atrophy... The same goes for your brain.
I am 65 years old. Many people my age are 'losing it', because they simply stop exercising their brains. I don't want to be one of those. So, I look for challenges of this sort, to try to work out, in my brain, before I actually lay my hands on anything.
Most of you are a fraction of my age. And as I said, you are free to laugh. I will laugh right along with you. But while I do, I'm also going to be flexing my brawny brain at yall!![]()
Honestly, I think it is impossible. Unless... there is something else not quite right with the wiring.But now I hope someone with a bit more knowledge about this stuff, can explain to me how not having contact #5 connected to anything at all on the truck.... (It was just a dead end on the connector.)
Leads to the light on the trailer working fine on the running lights, but getting turned completely off, when the right turn signal or brake are activated on the truck.
No signal of any kind was getting from the truck to the trailer through that contact. It wasn't sending power to the light. And it wasn't acting as a ground for the light. So how could it possibly have had any affect at all on the light on the trailer?
And doesn't, when the left turn signal is flashing. I don't really care about that. Cool thing is, though, if the hazard lights are flashing, then all 3 flash. And it still lights up as the 3rd brake light. 3rd brake light is essentially acting as a second right turn/stop lamp.
