Couple of points folks often forget.....
1) Disconnect your glow plug relay, or otherwise disable your glow plugs!
2) Disconnect the IP fuel return until you get fuel there
3) Take your glow plugs out if you're having problems with your mechanical pump getting fuel to your IP, so your cranking draws less power.
4) Do the electric fuel pump mod!
