Quality Synthetics in your driveline are proven friction reducers. I remember about 25 years ago for a demonstration we would take a cold 4x4truck with regular gear lube in the pumpkins and get someone to try to push it on flat ground, then keep adding guys to see how many it would take to budge the thing., then we'd switch the gear oil over to Amsoil gear lube and try the same experiment and watch everyone freak while one guy pushed the cold truck! Gear lube puts a lot of resistance in your system, get rid of as much resistance as possible, use quality lubes wherever you can and it will pay for itself in the long run.
Running 8.5 deg timing is for the old high sulfur fuel, your mileage will suck at 8.5, run it up to around 9.7 and it will compensate for the new ULSD fuel and you will get the mileage and power back that was lost when the new fuel was released
